Monitor the status of your jobs, filter the job view, view job details, monitor memory and core utilization, view
a list of job files, or perform job actions.
Open a remote desktops in a new window and work on the interactive
application.
You can also connect to a remote desktops from the Job
Monitoring page or the Job Summary page. Refer to Connect to a Remote Desktops
for more information.
Click the Desktops tab located in the upper left-hand of
the page.
Remote Desktops list is displayed. Figure 1. Remote Desktops List
Right click a remote desktops name and click Open Desktops in New
Tab
A remote desktops of the interactive application is opened in a new
window. Figure 2. Opened Remote Desktops
Note: By default, the timeout interval when a remote desktops is opened is set
to unlimited. The default configured timeout value is set to 120 minutes (2
hours) for a remote desktops and it is displayed in the remote desktops
tile. Time out will start when the remote desktops is closed, and the
remaining time is displayed in the remote desktops tile.
Click to view the remote desktops
options.
Note: The remote desktops control displayed is a floating panel which can be
moved.
Figure 3. Remote Desktops Control
The remote desktops control options are displayed. Figure 4. Remote Desktops Control Options
The following options are displayed:
- change the
resolution
- copy text to clipboard
modal
- expand the remote desktops in full screen
- collapse the remote desktops
from full screen. This option is displayed only when the remote desktops
is expanded in full screen.
- screen capture of the remote desktops
- share the remote desktops
- terminate the remote desktops
- view and switch to other active remote desktops
- change the desktops quality
settings.
- download desktops performance statistics.
This option is displayed when you enable statistics in the Preference
panel.
