Ideal Steer Angle
Request Number: 80000280
| .plt File | .mr, .abf File | Component | Unit | Comment |
| F1 | RESULT(1) | Not Used | Not Used | Not Used |
| F2 | RESULT(2) | 1 (X): Ideal Steer Angle | deg | The outside wheel steer angle required to produce a turn radius equal to the
                  turn radius produced by the inside wheel steer angle. It is calculated with the
                  following equations:
| F3 | RESULT(3) | Not Used | Not Used | Not Used |
| F4 | RESULT(4) | Not Used | Not Used | Not Used |
| F5 | RESULT(5) | Not Used | Not Used | Not Used |
| F6 | RESULT(6) | Not Used | Not Used | Not Used |
| F7 | RESULT(7) | Not Used | Not Used | Not Used |
| F8 | RESULT(8) | Not Used | Not Used | Not Used |
