SVSA Fore/Aft and Vertical Location
Request Number: 80000150
| .plt File | .mr, .abf File | Component | Unit | Comment |
| F1 | RESULT(1) | Not Used | Not Used | Not Used |
| F2 | RESULT(2) | Left Wheel SVSA Fore/Aft Location | mm | The longitudinal distance between the left wheel center and the left wheel
                  center side view instant center or: length * cos(angle) See left wheel side view swing arm length and angle calculations in BranchID 140, F2/RESULT(2) and F5/RESULT(5) (in Side View Swing Arm Length and Angle).  |
| F3 | RESULT(3) | Right Wheel SVSA Fore/Aft Location | mm |
                   The longitudinal distance between the right wheel center and the right wheel center side view instant center or: length * cos(angle) See right wheel side view swing arm length and angle calculations in BranchID 140, F3/RESULTS(3) and F6/RESULTS(6) (in Side View Swing Arm Length and Angle).  |
| F4 | RESULT(4) | Average SVSA Fore/Aft Location | mm | The mean of the left and right wheel side view swing arm fore/aft location. |
| F5 | RESULT(5) | Not Used | Not Used | Not Used |
| F6 | RESULT(6) | Left Wheel SVSA Vertical Location | mm |
                   The vertical distance between the left wheel center and the left wheel center side view instant center or: length * sin(angle) See left wheel side view swing arm length and angle calculations in BranchID 140, F2/RESULTS(2) and F5/RESULTS(5) (in Side View Swing Arm Length and Angle).  |
| F7 | RESULT(7) | Right Wheel SVSA Vertical Location | mm |
                   The vertical distance between the right wheel center and the right wheel center side view instant center or: length * sin(angle) See right wheel side view swing arm length and angle calculations in BranchID 140, F3/RESULTS(3) and F6/RESULTS(6) (in Side View Swing Arm Length and Angle).  |
| F8 | RESULT(8) | Average SVSA Vertical Location | mm | The mean of the left and right wheel side view swing arm vertical location. |
