Lateral Force Deflection
Request Number: 80000070
| .plt File | .mr, .abf File | Component | Unit | Comment |
| F1 | RESULT(1) | Not Used | Not Used | Not Used |
| F2 | RESULT(2) | Left Parallel Lateral Force Deflection | mm/kN | The left wheel center global lateral deflection due to parallel lateral
                  forces on the left and right tire patches or: 1000*(C(2,2) + C(2,4)*slr + C(2,8) + C(2,10)*slr)  |
| F3 | RESULT(3) | Right Parallel Lateral Force Deflection | mm/kN | The right wheel center global lateral deflection due to parallel lateral
                  forces on the left and right tire patches or: 1000*(C(8,2) + C(8,4)*slr + C(8,8) + C(8,10)*slr)  |
| F4 | RESULT(4) | Average Parallel Lateral Force Deflection | mm/kN | The mean of the left and right parallel lateral force deflection. |
| F5 | RESULT(5) | Not Used | Not Used | Not Used |
| F6 | RESULT(6) | Left Converging Lateral Force Deflection | mm/kN | The left wheel center global lateral deflection due to converging lateral
                  forces on the left and right tire patches or: 1000*(C(2,2) + C(2,4)*slr - C(2,8) - C(2,10)*slr)  |
| F7 | RESULT(7) | Right Converging Lateral Force Deflection | mm/kN | The right wheel center global lateral deflection due to converging lateral
                  forces on the left and right tire patches or: 1000*(C(8,2) + C(8,4)*slr - C(8,8) - C(8,10)*slr)  |
| F8 | RESULT(8) | Average converging Lateral Force Deflection | mm/kN | The mean of the left and right converging lateral force deflection. |
