Create Frequency Responses
Create modal frequency responses for the entire model. The resulting response is the frequency of the given mode shape.
From the Design Explorer ribbon, select the Responses
tool.
- Use the dropdown menu on the left side of the guide bar to select Frequency.
- On the guide bar, click to create the response.
- Make any additional modifications to the created response in the microdialog.
