Create Buckling Responses
Create buckling load factor responses for the entire model.
                From the Design Explorer ribbon, select the Responses
                        tool.
 - Use the dropdown menu on the left side of the guide bar to select Buckling.
                On the guide bar, click
 to create the response.
             - Optional: Make any desired modifications to the created response in the microdialog.
