Create Mass Responses
Create mass responses for the entire model or individual parts.
                From the Design Explorer ribbon, select the Responses
                        tool.
 - Use the dropdown menu on the left side of the guide bar to select Mass.
                Choose one of the following:
Option Description Note Model Create a response for the entire model. Parts Create a response for one or more parts. To create a response for each selected part, on the guide bar, click More Options, and turn on Add Response for Each Selection. To create a response only for the first selected part, turn off Add Response for Each Selection.
 - If you selected Parts in the previous step, select one or more parts.
                On the guide bar, click
 to create the responses.
             - Make any additional modifications to the created response in the microdialog.
