Tutorial: Adding Overflows and Cooling Lines
Observe how a cooler helps maintain a homogeneous temperature range throughout a mold, particularly in high pressure die casting.
In this exercise, you will learn how to analyze the effect cooling channels have on casting.
Model file is available in the tutorial_models folder in the installation directory in Program Files\Altair\2022.3\InspireCast2022.3\tutorial_models\cooler.x_b.
Import Geometry
Designate a Casting Part
