MATT1PT
Bulk Data Entry Defines temperature-dependent isotropic permittivity via the TABLEM1-4 or TABLEG Bulk Data Entries for dielectric materials.
| MATT1PT | MID |
| MATT1PT | 1 | 1001 |
| MID | Material property
identification number. Must match the identification number on MAT1PT Bulk Data Entry. No default (Integer > 0) |
| Identification number of
the TABLEM1-4 or TABLEG Bulk Data Entries defining
temperature dependent permittivity. Default = blank (Integer > 0) |
- The quantities defined on the MAT1PT Bulk Data Entry are multiplied by the tabular function referenced in the MATT1PT Bulk Data Entry to generate the corresponding material data.
- If the fields are blank or zero, then constant properties defined on the MAT1PT Bulk Data Entry are used.
- For more information, refer to Piezoelectric Analysis in the User Guide.
