SENSOR
Bulk Data Entry Sensors may be used to activate loads.
SENSOR SID STYPE
Continuation line if STYPE=TEMP
  LSID GID LBOUND/LTID UBOUND/UTID
SENSOR 2 TEMP 4
  4 933 100.0 200.0
SID Unique sensor identification number.
No default (Integer > 0)
STYPE Sensor type.
TEMP
Temperature. 1 2
No default
LSID Load set identification number of a QBDY1 or QVOL Bulk Data Entry.
GID Grid or scalar point identification number.
LBOUND/LTID Lower bound of the temperature range, or the table identification number of a TABLEDi entry which specifies the lower bound as a function of time.
No default (Real or Integer)
UBOUND/UTID Upper bound of the temperature range, or the table identification number of a TABLEDi entry which specifies the upper bound as a function of time.
  1. A SENSOR can only be activated once. Sensor with TYPE=TEMP is supported only for Transient (linear and nonlinear) Heat Transfer analysis.
  2. The presence of the SENSOR Bulk Data Entry with TYPE=TEMP turns off the referenced LSID loading outside the defined temperature range and turns on the LSID loading inside the temperature range (LBOUND/LTID to UBOUND/UTID).
