METADATA
Bulk Data Entry METADATA indicates the beginning of metadata content that is to be passed to the OUTPUT2 (.op2 file).
METADATA
This line and any line below it will be passed to the .op2 file.
  1. The METADATA entry can only be present in the Bulk Data section.
  2. The METADATA entry can be used to pass information from the pre-processor seamlessly through the solver to a post-processing program.
