*DATABASE
LS-DYNA Input Interface KeywordDefines the output frequency for time history data.
(1) (2) (3) (4) (5) (6) (7) (8)
*DATABASE_{OPTION}
DT
Definition
OPTION Time history output type.
ABSTAT
Airbag data.
BNDOUT
Nodal reaction force for imposed movement.
DEFORC
Spring.
DISBOUT
Beam element.
ELOUT
Element.
GLSTAT
Global variable.
JNTFORC
Joint.
MATSUM
Energy by parts.
NODOUT
Node displacement and rotation.
RBDOUT
Rigid body movement.
RCFORC
Resultant contact force.
RWFORC
Rigid wall.
SBTOUT
Seatbelt accelerometer.
SECFORC
Cross section force.
SPCFORC
Boundary condition force.
SWFORC
Spotweld force.
DT Time frequency for writing time history output.
(Real)
[s]
  1. This keyword maps to /TFILE/4. The minimum time interval from all the *DATABASE_{OPTION} defined is used.
  2. The card controls only the frequency of the output. An additional card may need to be defined to specify which objects will be output. For example, number of nodes, elements, the definition of section force, and so forth.
