*MAT_B01 (SEATBELT)
LS-DYNA Input Interface KeywordDefines a 1D seatbelt material.
(1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
*MAT_B01 or *MAT_SEATBELT | |||||||
mat_ID | fct_load | fct_uload | Lmin | E | |||
A | I | J | AS | Fmax | Mmax | R |
Definition
mat_IDmat_ID | Material
identifier. (Integer) |
Mass per unit
length. (Real) |
fct_load | Curve identifier for force versus
engineering strain in loading. (Integer) |
fct_uload | Curve identifier for force versus
engineering strain in unloading. (Integer) |
Lmin | Minimum length for elements
connected to slipring and retractors. (Real) |
E | Elastic modulus for
bending/compression stiffness. (Real) |
A | Cross-sectional area for
I | Area moment of
inertia. (Real) |
J | Polar moment of
inertia. (Real) |
AS | Shear area. (Real) |
Fmax | Maximum force in
compression/tension. (Real) |
Mmax | Maximum
torque. (Real) |
R | Rotational mass scaling
factor. (Real) |
- This keyword maps to /MAT/LAW114 (SPR_SEATBELT) and /PROP/TYPE23 (SPR_MAT).
