*ELEMENT_DISCRETE
LS-DYNA Input Interface KeywordDefines a 1 degree of freedom spring element.
(1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
*ELEMENT_DISCRETE | |||||||
EID | part_ID | N1 | N2 | VID |
Definition
EID | Element identifier. (Integer) |
part_ID | Part identifier. (Integer) |
N1, N2 | Node identifier. (Integer) |
VID | Direction identifier.
(Integer) |
- This keyword maps to /SPRING.
