*MAT_071 (CABLE_DISCRETE_BEAM)
LS-DYNA Input Interface KeywordThis keyword defines an elastic cable material with no stiffness in compression.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *MAT_071 or *MAT_CABLE_DISCRETE_BEAM | |||||||
| mat_ID | E | CID | F0 | ||||
Definition
| mat_ID | Material identifier. (Integer) |
| Initial density. (Real) |
| E |
(Real) |
or |
| CID | Curve identifier for engineering stress versus engineering strain.
(Integer) |
| F0 | Initial preload (tensile) force. (Real) |
- This keyword maps to /MAT/LAW113 (SPR_BEAM).
- The material is only used with *SECTION_BEAM, ELFORM = 6 discrete beam elements.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
