Spot Weld Fatigue Analysis
Allows for the study of fatigue performance of spot welds in structures.
Implementation
Fatigue analysis for spot welds involves examining the weld at three distinct locations, the sheets and nugget, and is based on a paper by Rupp et al. The cross-sectional forces and moments at the nugget location are determined and used to calculate corresponding stresses at the sheets and the nugget. These stresses are then used to calculate Fatigue Damage using Rainflow counting and the SN approach.
The following sections illustrate how stresses and subsequently damage are calculated at each of the three locations.
Sheet Location (1 or 2)
- Diameter of the weld element
- Thickness of the sheet under consideration for damage calculation
- Scale factors
- Diameter exponents
- Thickness exponents
To be equivalent to the Rupp method:
The equivalent radial stresses are calculated at intervals of (Default =18 degrees). The value of can be modified by varying the Number of angles field in the spot weld solution settings. Subsequently, Rainflow cycle counting is used to calculate fatigue life and damage at each angle ( ). The worst damage value is then picked for output. A similar approach is conducted for the other sheet.
Nugget Location
The equivalent maximum absolute principal stresses are calculated for each from and . These stresses are used for subsequent fatigue analysis. Rainflow cycle counting is used to calculate fatigue life and damage at each angle ( ). The worst damage value is then picked for output.
