Apply Global Solution Settings
Apply solution settings to the entire assembly.
- In the main toolbar, click .
In the dialog, choose one of the following options:
Option Procedure Adapt for stiffness Select the Adapt for stiffness option from the drop-down menu. - Best for general load path prediction, modes and/or thermal analysis.
- Uses 3 adaptive passes and global adaption.
- Typically the fastest solution method.
Adapt for stress Select the Adapt for stress option from the drop-down menu. - Best for general stress calculation.
- Uses 4 adaptive passes, Adapt to features, Adapt to thin solids, and global adaption.
Custom - Select the Custom option from the drop-down menu.
- Define the max number of adaptive solution passes. This rarely needs to be more than 6.
- Optional: select the Adapt to features check box.
- Optional: select the Adapt to thin solids check box.
- Click OK.
