Apply Local Solution Settings
Apply solution settings to groups of parts in the assembly.
- In the Project Tree, right-click Solution settings and choose Edit.
Specify the Max number of adaptive solutions.
Note: This rarely needs to be higher than 6.
Click the New button.
A new group will appear in the Group list.
In the modeling window, select one or more parts for
the group.
Tip: You can also select parts from the Project tree.
- Optional: Click the Adapt to features check box.
- Optional: Click the Adapt to thin solids check box.
- Specify Refinement level.
- Click Apply.
