Edit Results Images/Animations
Edit simulation modeling and results images/animations.
Prepare the image/animation you want to save using one of the following
processes:
Action Process Create an Image Left-click and drag in the modeling window to rotate the model, or right-click and drag to pan the model, until it is positioned as desired. Create an Animation In the Analysis workbench toolbar, click the (Results plot) icon and choose the desired plot to display in the modeling window.
Edit an existing bookmark in any of the following ways:
Action Update Bookmark Right-click on the thumbnail and choose Update in the context menu. This will update the bookmark to the current display. Edit Bookmark Name - Right-click on the thumbnail and choose Rename in the context menu.
- Enter the desired name in the text box below the thumbnail.
Add/Edit Captions - Right-click on the thumbnail and choose Add/Edit caption in the context menu. A text box will appear in the Bookmark Browser.
- Enter the desired caption in the text box.
- Click Save.
Control Thumbnail Size Use the and
buttons to increase and decrease thumbnail size respectively. To make the current thumbnail size the default fir subsequent sessions, right-click on the bookmark and select Set as default size in the context menu.
Reorder Bookmarks Right-click on the thumbnail and choose either Move up or Move down in the context menu. Delete Bookmark Right-click on the thumbnail and choose Delete in the context menu. -
Position the Bookmark Browser in the application
window.
- Click the Bookmark Browser title bar and drag the window to undock it from below the Project Tree. To redock it, drag it to the left or right of the application window and release the title bar. The application will suggest docking locations as you drag.
- Drag to the top or bottom 1/3 of the Project window to dock the Bookmark browser above or below the Project tree.
- Drag to the middle 1/3 of the Project window to dock the Bookmark browser as a tab window with the Project tree. Toggle between the Project Tree and Bookmark Browser views with the tabs at the bottom of the application window.
