Console Execution
- On a PC, open a DOS Command Prompt window and run the following command: <install directory>\Compose_Console.bat –f <inputfile>.oml
- From a Linux shell, run the following command: <install directory>/scripts/Compose_Console –f <inputfile>.oml
This runs the OML script <inputfile> in Console mode. This is executed in batch mode unless the OML script <inputfile> contains print statements, such as printf, disp, and assignment, then this is silent and OML quits after the script is executed.
Additional options are described in the Console Mode Start Options topic.
