Console Mode Start Options
Option | Argument | Description | Platform Support |
-f | <filename>.oml |
Runs the specified file(s). If multiple files are provided, they are executed in the order provided on the command line. Requires absolute file paths as the argument (separated by ','). |
All supported platforms. |
-e | None |
Runs the OML command specified after the –e option. If multiple commands, they are separated by a comma and executed in the order provided on the command line. -e disp('a') -e "a=3 , rand(3)" |
-continue | None | Use the –continue command line argument to keep the console application opened after running any –e commands and –f files. If –continue is not provided, the console program exits after running all the commands and files. | |
-help | None | List the options when invoking Compose in batch mode. | All supported platforms. |
-input | <space separated inputs> | Passes input(s) to scripts. These options can be accessed in Compose by the OML commands
getcmdinput and getnumofcmdinputs. To pass
cell arrays or matrices on Linux, the open/close braces
and semi-colons need to be quoted. Linux example: -input ‘{‘ 1,2,3 ‘} ‘[‘ 4 ‘;’ 5 ‘]’ stringA Windows example: -input {1,2,3} [4;5] stringA |
-version | None | Returns the version of Compose | All supported platforms. |
