2D CAD export starting from a cut of objects
Introduction
In the modeler context, it is possible to export in a 2D CAD file a cut of 3D object.
The user chooses a reference plane and objects from which he wishes to export the section.
The intersection between the reference plane and selected objects made a 2D projection of points, lines and faces. These entities are exported in a CAD file.
This export allows especially to switch from 3D model to 2D model.
The possible export formats are:
- CATIA V5
 - STEP
 - SAT
Access
The access (in the modeler context) to the 2D CAD export is:
- By menu:
