Mesh elements generation
Definition
The generation of mesh elements (or meshing) is the process of subdivision of lines, faces and volumes into finite elements, carried out by Flux.
Meshing
The mesh generation is carried out in the following way:
Stage | Description | Command |
1 | Meshing the lines | Mesh lines |
2 | Meshing the faces | Mesh faces |
3 (for 3D) | Meshing the volumes | Mesh volumes |
Mesh
To mesh:
Step | Action |
1 | Activate the Mesh command (see next block) |
→ | Flux generates mesh elements. |
In the graphic zone, Flux displays
Activate the command
To activate the Mesh command, choose one of the methods presented in the figure below:
