Deletion of the mesh
Mesh deletion
It is possible to switch from the geometry context to the mesh context. To modify a meshed geometry, it's necessary to first remove the mesh.
The mesh deletion:
  • removes mesh elements (nodes, line, face and volume elements)
  • retains meshing tools (mesh point, mesh line, mesh generator)
Delete mesh
To delete the mesh:
Step Action
1
Activate the command:
  • in the Mesh menu, click on Delete mesh
    or in the Mesh toolbar, click on the icon
A warning message box is open.
2
Confirm the deletion:
  • click on Yes
The mesh elements are removed.
