color()
Set\get color of an actor.
Usage
actor.color( red = None, green = None, blue = None )
red (real)
Transparency value.
green (real)
Transparency value.
blue (real)
Transparency value.
Return Value
List( of RGB )
If red = None and green = None and blue = None, the current RGB value will be returned, or else None.
red, green and blue must be Real values.
This routine sets\gets color value of an actor. If red, green and blue are None, the current red, green and blue values of color will be returned. For example,
fan = vis.getSrfActor( "impeller" )
fan.color( 0.5, 1, 0.4 )
or :
fanColor = fan.color( )
