pointSize()
Set\get point size of an actor.
Usage
actor.pointSize( size = None )
size (integer)
Point size of an actor.
Return Value
Integer
If size = None, the current size value will be returned, or else None.
size must be integer.
This routine sets\gets the size value of an actor. If size is None, the current point size value will be returned. For example,
fan = vis.getSrfActor( "impeller" )
fan.pointSize( 2 )
or :
fanPntSize = fan.pointSize( )
