getOriValues()
Return the list of ORI integrated values.
Usage
oriVals = adb.getOriValues( name, var, unit = None )
name (integer) or (string)
Name or ID of an ORI name.
var (integer) or (string)
Name or ID of an ORI variable.
unit (string)
If unit is not None, the value will be converted to the new unit and be returned.
Return Value
oriVals (list)
List of ORI integrated values.
This routine returns the list of ORI integrated values. This function needs two indices as argument which are given by name and var. If unit is not None, the value will be converted to the new unit and be returned. For example,
trac = adb.getOriValues( "wall", "traction", "N" )
