getSolRatioSteps()
Return the "Solution Ratio" steps value.
Usage
solRatioSteps = adb.getSolRatioSteps( var, type = 'all' )
var (string) or (integer)
The "Solution Ratio" variable name/index.
type (string)
The type value; 'all', 'initial' and 'final'.
Return Value
solRatioSteps (numarray)
The "Solution Ratio" step values.
var must be a valid name or index.
type must be 'all', 'initial' or 'final'.
This routine returns the "Solution Ratio" steps value. The "Solution Ratio" name or index is given by var. For example,
solRatioSteps = adb.getSolRatioSteps( 'pressure' )
