Specific Options
| Option | Arguments | Notes |
solver |
Solver symbol | Abbreviated name of the solver.
These are useful when you want to start the ACC with the
filename and options filled in from the last run of this
solver.
screen |
<none> | Start solver with the Solver View form as opposed to text only window. |
setenv |
<NAME=VALUE> | Add specific environment variable when running the solver. |
delay |
<# seconds> | Introduce additional delay before starting the solver. Delay starts after job is started from the internal queue or PBS queue. |
savelog |
<none> | Capture the terminal output
(stdout) from the solver to a file named
<filename>.Log. Where, filename is the root part of the input file name. Requires Solver View form (use option
rundir |
<path> | During local run, request to copy all required input files to a specific location before the run. This option has similar meaning during the submission of remote job. |
dir |
<none> | Before starting the run, change current directory to the location of the input file. |
bg |
<none> | Submit job in the background
(useful in the command mode when submitting from the
ssh or remote desktop session). It allows
you to close the connection before completing the run. Note: Job
will be submitted to the queue, but it will be immediately
treated as completed and the next job in the queue will be
triggered. This option is incompatible with PBS
submission.
lsexec |
<none> | List all executables available in
the current installation (example, when solver has multiple
patch releases installed, or to check if specific
mpi type is supported). |
exec |
<path> | Enforce specific name and location of executable or main solver script to start. |
The above options are available for any solver, while most of the options listed below may be solver specific.
Shared Between Different Solvers
help |
<none> | Print to the output a list of available options with short help. |
version |
<none> | Print the version info for the solver (build date, release number, ...). |
manual |
<none> | Opens in the browser user documentation for the currently selected solver. |
v,
altver |
<string> | Allows to select specific
executable from the list showed by -lsexec,
example -v 2020.1. Supported by OptiStruct and OptiStruct solvers. |
sp |
<none> | Activate single precision version of the solver (OptiStruct, OptiStruct). |
args |
<arguments> | Appends the list of additional
arguments to the solver command line (in the syntax appropriate
for the specific solver executable).
Example: |
gpu |
Optional: <CUDA> | Activate GPU computations. |
gpuid |
<integer> | Use specific GPU card (1,2,..), when host has more than single GPU installed. |
ngpu |
<integer> | Use more than one GPU card when
installed, uses n consecutive cards starting
from the one selected with -gpuid. |
gputype |
<cudadp> | Activate double precision GPU computations on NVIDIA GPU. |
- These options may or may not be supported by each solver. Verify with solver specific manual for detailed information about such options.
- The value passed to the
-argsoption has to be interpreted bytclsh(internal to ACC) thus requires non-intuitive quoting for spaces and special characters. Usually the value of this option contains multiple options and values attached to the final command line separated by spaces and the quoting is as in the example – whole list is quoted by double quotes (if used in ACC GUI) or by single quotes (if used on Linux command line), each argument is enclosed in curly braces, if it contains spaces, and quotes, parentheses or backslashes internal to each argument may need to be quoted by backslash.
Multiprocessor Run Options
- Shared memory parallelization, often
referred to as multi-threading, SMP, or OpenMP. The solver runs as a single
process on a single computer host and uses internally multiple cores to
speed up operations which can be performed concurrently. To start the solver
in this mode use option ‘
-nt N’. Typically, it is expected that the valueNon this option will not exceed the actual number of available cores, but it is not an error to use largerN(check the manual in such cases). - Distributed processing parallelization,
also called message passing (or MPI), or SPMD. In this mode,
the external utility (usually named
mpirun) is started first, and this utility starts multiple instances of solver. These instances communicate with each other as needed, as they typically each handle part of all data – all these instances can be started on a single host or on a cluster of hosts, but internally it does not matter to how the solver does its job. To start the solver in this mode, use option-np Nand add-hostsor-hostfileoptions to define which hosts should be used by multiple instances of solver. When only the-npoption is used, all instances will run on a single host. When-npis not present, but-hostsor-hostfileoptions are present, the ACC assumes-npis equal to the total number of declared hosts. - In MPI mode, each instance of the solver
can internally run in OpenMP mode to speed things up, this is sometimes
called mixed mode and is often faster than pure MPI or pure
OpenMP. To start the solver in this mode, together use options from both
groups above, example,
-np N1-nt N2. These two modes are independent and can usually be mixed easily during programming. - In general, both types of parallelization
expect that there are enough CPUs and hosts available, but there is nothing
wrong with running MPI job even on a host with a single core CPU (if you can
find one today). In some cases – example being OptiStruct MMO mode – the value of
-npis dictated by the solver or specific input data, not by the available hardware. - Usually, MPI runs are performed on a group of hosts similar in size and hardware, but theoretically it is possible to start MPI run with hosts using different architecture, and even different operating systems. This topic is outside of the scope of ACC.
There is no general rule which mode of execution is better. Not every program can be
parallelized, and some codes may not profit from one or another mode of
parallelization. Finding the optimum choice is often only possible after several
trials and errors; however, for each solver there are some simple ‘rules of thumb’
and this is the magic inside the -cores option.
The intent of -cores is to allow you to expect good performance
without knowing how to split between -nt and -np,
and without even knowing how the hosts are configured. In particular: -cores
auto will try to test the host, or all available hosts, if defined with
-hosts/-hostfile options, and it will try to
use all available cores with optimal split between OpenMP and MPI. Of course, this
split will be based on simple and safe rules of thumb, which will be different for
each solver.
In ACC, during the remote execution in the queuing environment like PBS or LSF,
-cores option cannot be resolved on a local host, so it is
‘shipped’ to the remote host, when the installed version of the ACC package is
executed after the queuing system decides how many and which hosts are to be used.
However, you will still need to decide how many hosts are available and define this
information during submission.
-cores auto. It tells ACC to probe the host
for how many cores are available, and use all of them, splitting into mixed
multi-processing mode, if available and desirable. For OptiStruct this will trigger as many 4-cores processes as
possible, and for Radioss it will not use mixed mode,
using each core to run a process. ACC will not be able to detect if HyperThreading
is active and; therefore, the choice may not be optimal, if it is active. Not all
programs, but typically most engineering solvers based on finite elements or similar
technologies, may not profit from HyperThreading, and sometimes may run faster when
HyperThreading is disabled, so check with your solver support what is the best
choice. - Using
-cores auto-np Nis seldom appropriate, but is possible. ACC will probe the host (or hosts, if specified) and decide on value for-ntoption based on available cores.
When you specify the number of CPUs using (example, -cores 32), ACC
will start MPI mixed mode without verifying that this is the actual number of
available cores. When the host has more than 32, any extra cores will remain idle
(maybe available to run something else), when the actual number of available cores
is smaller than 32, then processes will run in turns. This is acceptable, although
it may not be optimal. Some solvers (example, OptiStruct), may refuse to use more cores per process than actually available, but OptiStruct will allow running as many cores as you request,
as long as each process does not use more than what is available.
-cores auto
-hosts h1,h2,h3,h2 or using -hostfile option, will
let ACC decide automatically how to split all available cores into mixed mode run.
ACC will probe all the hosts (skipping duplicates on the list) and decide on the
appropriate allocation. When hosts have different hardware (different number of
cores per host), ACC will use the same number of actual cores on each host.
nt |
<integer> | Number of cores to use for OpenMP run, number of cores used for each process in MPI parallel run. Some solvers accept different (but equivalent) named options. |
cores |
<auto, integer> | Total number of cores used for the
OpenMP or MPI run. When specified as ‘auto’,
the ACC probes the systems assigned for the run, and tries to
internally set the arguments in optimal way for a given solver.
May be used in remote and/or MPI runs. See below for a more
detailed explanation how -cores is translated
into best values for
-np/-nt. |
np |
<integer> | Number of MPI processes to start. |
hosts |
<name,name,..> | List of hostnames to be used. |
hostfile |
<path> | File describing list of hosts to be used for the computations. |
appfile |
<path> | File with advanced definition of MPI processes to run (advanced option). |
mpi |
<vendor> | Select non-default version of MPI,
if applicable for a solver.
For most solvers default is Intel MPI. |
mpipath |
<path> | Execution path for MPI package. |
mpiargs |
<args> | Additional arguments passed to
mpirun program. See |
mpitest |
<none> | Run simple test example to verify that MPI installation is configured properly. |
- For MPI runs, it is necessary to provide
enough information for ACC (or PBS) to know how many hosts/processes should
be used. Usually either
-np,-hosts, or-hostfileis sufficient. - When
-hostsis combined with-cores, possible duplicates in the hostnames will be deleted. - The simplest format of hostfile is usually one hostname per line.
- Format of hostfile is specific to each MPI distribution, verify with vendor documentation.
- Use of
-appfilewill often override some items which ACC uses to run a solver. In particular, the name of executable and arguments to call on each host will be used as defined in this file. -mpitestis available only when Altair HWSolvers package is installed.- For historical reasons, some solvers may use option names which do not conform to the above list.
- Verify with solver manual if the solver supports multi-processor runs, what types of multi-processing is available, and specifically, which MPI vendors are supported.
Remote Submission Options
remote |
<server name> | Submit job on remote server, not on the local host. |
pushfile |
<path> | Additional filename to be copied to remote server. |
filelist |
<path> | File containing a list of input files to be copied to a remote server, see below for the file format description. |
jobstatus |
<name> | Inquire about the status of remote job. |
pbschunks |
<integer> | Number of MPI processes requested. |
pbscpu |
<integer> | Number of cores requested per each process. |
pbsmem |
<integer> | Size of memory needed for each process (GB). |
showremotejobs |
List of jobs submitted to remote servers. |
Advanced Options
force |
<none> | In batch mode: do not ask any questions, even if ACC would normally ask for details or confirmation. |
debug |
<integer> | Activate additional prints for debugging internals of the ACC. |
quiet |
<none> | Suppress warning messages. |
pathonly |
<none> | During the batch run – print the
location of chosen exec to the stdout and
terminate batch run. Intended use is when ACC scripts are
invoked inside another utility. |
argsonly |
<none> | As above – but print all arguments
passes on the command line when starting executable. In the case
of MPI run, this will not include args passed
directly to
mpiexec/mpirun. |
gui |
<none> | Start ACC application. |
icon |
<none> | Start ACC application; however,
when filename is appended after to the command line, the solver
run is started in the background. -icon should
be used instead of -gui when defining a desktop
icon capable to accept drag-n-drop files for execution. |
acu_fsi |
filepath | AcuSolve input file during the FSI co-simulation. Useful to start FSI run from the command line or inside the script. |
acu_fsi_args |
arguments | Arguments to be passed to the
AcuSolve during the FSI run.
When multiple arguments are to be added, they should be properly
quoted (using quotes appropriate for the current shell, or curly
braces when called from the tclsh). |
solvtype |
<none> | Return the solver macro detected by analyzing input filename, its content, and any options, OS for OptiStruct, RD for Radioss, and so on. |
verify |
<none> | Analyze arguments and return any detected errors (contradictory options, missing input file or specific executable). |
genjobid |
<none> | Initiate preparation of remote server for a new job. Returns unique job name. |
manual |
<none> | Initiate web browser with URL or local file appropriate for the current solver. |
hw_manual |
<none> | Initiate web browser with URL or local file representing top of the HyperWorks help tree. |
support |
<none> | Initiate browser with URL to HyperWorks support page. |
web |
<none> | Initiate web browser with the URL to main HyperWorks server. |
apps |
<app name> | Invoke specific HyperWorks app, if it is available. This is called from the main menu ‘Apps’ on ACC GUI. |
Batch Mode Options
- Command line syntax for batch
execution.
ACC is written almost entirely in Tcl/Tk and the command line must follow that syntax. The main implication is how to properly quote strings containing spaces and special characters, and in some cases it is necessary to quote within quotes. Then there is interaction of syntax of the shell used to execute the command, which may have different quoting rules, and there is no way to discuss all special cases here. Similar quoting requirements apply when entering options in the GUI entry fields.
Double quotes are used to allow the spaces inside the names, typically filenames:acc -core in “path with spaces/input.fem”Curly brackets are used to prevent special characters (example, backslash) from being treated as special characters.acc -core in {C:\path with spaces\input.fem}This will also work:acc -core in {path with spaces/input.fem}A backslash can be used to escape single character. In this case, spaces are part of the name, instead of separating items in the line:acc -core in path\ with\ spaces/input.femACC has special options (-args,-mpiargs,-acu_fsi_args) which allow an arbitrary list of arguments to be passed down to a next phase of execution. Here are examples how to achieve quoting in such cases:acc … -mpiargs “ -envall -n 6 ” acc … -args { -core=in -name={Program Files\WINDOWS\etc} }Here, nested brackets are used, outside brackets to group two parts into the value to-args, inner brackets are needed to protect space and backslashes inside this single filename.Note: The space before the-core…is required, as it preventsaccfrom reading the minus in-core=inas a name of option. - Batch execution of FSI run
Two options specified for FSI runs are:
-acu_fsiand-acu_fsi_argsTo invoke batch execution of any solver with AcuSolve (where ‘any solver’ currently may be, example, OptiStruct, MotionSolve or EDEM), the arguments for AcuSolve must be passed as a single value for-acu_fsi_args:<ALTAIR>/common/acc/scripts/acc <input for MS> <args for MS> -acu_fsi {file for AS} -acu_fsi_args {args for AS}In the example inside HyperShape, it could be:… -file Motion.xml -solver MS -nt 2 -acu_fsi ${root filespec_resource} -acu_fsi_args " -args { -np 4 -tlog } "Note:${root filespec_resource}is part of the shell used by HyperShape, so the ACC will receive this part as:-file Motion.xml -solver MS -nt 2 -acu_fsi file_0005 -acu_fsi_args " -args { -np 4 -tlog } " - Remote job submission in the batch
mode
Options specific for the remote execution are
-remote,-copyoptions,-jobstatus. In addition, for PBS server there are-pbschunks,-pbscpu,-pbsmem. Related options are also-pushfileand-filelist.To submit a job to any remote server, simply append-remote <remote_name>to the command used for local execution, example:acc <input file> -remote Linux_server_1Optionally,-copyoptionsmay be used to define how to treat results:acc <input file> -remote Linux_server_1 -copyoptions fc:1,pc:0,dr:1-remote [name]- Submit job to a remote machine. Argument is the name of the remote machine that is configured in the GUI.
-copyoptions [name,value]- Options to copy the results from remote server (optional),
default is
fc:1,pc:0,dr:1(copy full results and delete results directory on remote). fc- Full copy
pc- Partial copy (post-processing files)
dr- Delete results directory on remote
0- Disables the option
1- Enables the option
When a job is submitted to a remote PBS server, additional resources may be specified.acc <input file> -remote Linux_server_1 -pbschunks 4pbschunks [value]- Number of chunks (optional), default is 1.
pbscpu [value]- Number of cpu’s (optional), default is 2.
pbsmem[value]- Memory in GB (optional), default is 4.
To check the status of any remote job, issue command:acc -jobstatus flock_122jobstatus [name]- Check status of remote job submitted. Argument is JOBID generated by ACC.
showremotejobs- List jobs submitted to remote servers. No argument is required.
Control List of Files Submitted (Remote Job)
include or similar
statements. Only some solvers are automatically handled for more complex job structure:- OptiStruct
solver has built-in capability to ‘preread’ the input data, and produce a
file containing a complete list (refer to the option
-inventory, in the OptiStruct Reference Manual). - Altair Manufacturing Solver (Injection Molding) input file (*.ams) contains a complete list of input files needed for the run, created by the pre-processor specific for the solver.
- For all other solvers, ACC has built-in
default rules to locate needed files, but such rules may not be sufficient
in some cases. You can still submit the run in these cases by adding more
files to the default selection, using options:
-pushfile <filename>- To add one file (option can be repeated as many times as needed).
-filelist <filepath>- Where argument to this option defines filename containing a list of files in XML format (identical to the one automatically created by OptiStruct).
- All files needed for the run (identified
automatically and added with
-pushfileor-filelistoptions) are copied to the same folder on a remote host where the solver is going to be executed. When input files are presented in the complex multi-level structure, their location on the remote server will not match such structure and the solver may not run properly. - For OptiStruct, the special option,
-aspallows running such a job correctly. - For any solver, ACC is not currently able
to properly submit the job when filenames overlap. In rare cases when this
happens, it is necessary to rename such files and modify
includestatements to resolve conflicts.
-inventory option: <results_catalog>
<input name="run.fem"/>
<input name="qadiags.inc"/>
<input name="../test_io/qadiags.inc"/>
<input name="../test_io/inc_1.fem"/>
<input name="../test_io/inc_2.fem"/>
<input name="../test_io/SUBDIR1/inc_11.fem"/>
<input name="../test_io/SUBDIR1/SUBDIR11/iii1.fem"/>
<input name="SUBDIR2/iii2.fem"/>
<data name="../testnp100/cms_cbn_testinrel.h3d"/>
</results_catalog>ACC does not read full XML syntax, and expects that the data will be presented one
file per line, as in the above example. In OptiStruct
inventory, keyword ‘input’ represents a text file, and keyword
data represents binary data, However, ACC treats these two
keywords the same way, the files are compressed using gzip,
transferred using either the scp or plink command,
and uncompressed at the other end.
