Solver View Form
Solver runs performed through the Compute Console will not use any xterm or a DOS window (the only exception is a DOS window appearing during certain MPI commands). All output from solver runs is captured by the Compute Console and presented appropriately using its own windows. By default, each solver run is performed in the Altair Simulation Solver View utility, shown in Figure 1 during a Radioss run. When ‘Use solver control’ is not checked (and -screen option not present in the command line), the simple text window opens to show output from the solver (Figure 2).
Figure 1. Altair Simulation Solver view after completed run
The top section of the form shows several fields containing the actual name of the Solver binary, name of the Input file, the Run command line with all options used to start the solver, and the estimated Progress of the solution.
There are two text fields in the center of the form; the Message log field shows messages from the solver (usually warnings and errors), while the Optimization summary field shows a table representing the convergence of solutions for different subcases in each optimization step. The Graph button inside the Optimization summary window allows you to open a simple X-Y plot and browse the dynamic convergence of various variables displayed in the Optimization summary window.
The Run summary field represents the standard screen output from the solver. For OptiStruct, it is recommended to use the option -out to increase the amount of information printed to the screen.
On the left side of the bottom row are additional buttons visible while the solver is running. These buttons communicate with the solver through an intermediate control file, and the amount of time it takes for the solver to react to these commands may vary, especially for large jobs. When the solver run is completed, an additional Results button may appear. The Results button appears only if the job creates some known types of visualization file types (h3d for Altair HyperView). It does not appear for OptiStruct check runs.
Abort
Stops the solver immediately. This may prevent the solver from removing all scratch/temporary files and results files will not be available.
Stop
Terminate at the end of the current optimization iteration. All output files are created as if the run converged successfully.
Pause
Pause the run. OptiStruct will return the license.
Results
Provides an easy way to start Altair Simulation (HyperGraph or HyperView) depending on which output files were created by the solver.
View
Allows you to select some other output files, either from the prepared list, or through the browser.
Graph
The browser recognizes typical Altair Simulation file extensions, and uses HyperGraph or HyperView to open files with extensions .h3d or .mvw. For other files, it opens a simple text viewer with search capability.
When the output filename(s) are changed by you; for example, by using the -outfile command or by the controls in the input deck, the Solver View utility will not be able to locate them automatically. The View > Browse option can be used to view such output files.
Abort/Stop/Pause buttons are specific for OptiStruct, other solvers may allow different controls.
Figure 2. Simple text viewer with example of an .out file
Figure 3. Optimization convergence history graph
Graph window (activated by a ‘Graph’ button, if available) shows the history of convergence (optimization convergence or nonlinear iterations convergence) from the data shown in the Optimization summary window. The actual content depends on the solver; for example, for OptiStruct it will show optimization convergence, maximum displacement for a selected subcase, or convergence measures for nonlinear iterations. The purpose of this window is to help decide if the solution process progresses satisfactory, and potentially to terminate the job when solution does not converge.
The controls along the lower edge of the graph window allow to: toggle between the Linear and logarithmic scaling of values; zoom view toward the left or right edge of horizontal axis, reset view (x) and select specific function to display, and subcase ID (when applicable).
The Solver View form controls are solver dependent. Some fields and options are available only during runs using certain solvers. For example, the Message log, Optimization summary fields and the Graph button are displayed during OptiStruct runs. Stop, Abort, and other similar options appear only during OptiStruct and Radioss runs. AcuSolve run will show the Solution summary window, with Graph button, but not the Message log window.
