Integrate Results on Entities
Use the Integration tool to get integrated quantities on surfaces, solids, volumes, slice planes, and iso-surfaces.
  1. From the Post ribbon, click the Integration tool.
  2. Select surfaces, solids, volumes, slice planes, or iso-surfaces.
  3. Click Calculate on the guide bar to extract values.
    A new Integration entity is added to the Post Browser,
    A table with extracted values for all variables is populated. This data can be saved to a text file.
  4. On the guide bar, click to confirm your selection and remain in the tool or click to confirm your selection and exit the tool.
