Generate Streamlines on Surfaces
Use the Surface Streamlines tool to create streamlines on surfaces with given seeds.
From the Post ribbon, click the Surface Streamlines
tool.
Figure 1. -
Select surfaces on which to generate seeds.
Tip: Click
to select surfaces "By Boundaries" or "By
Surface Outputs". - Click Seeds on the guide bar.
Click on the selected surface(s) to position the seeds.
- Click on an individual seed to modify its position.
- Optional: Define the streamline direction and vector variable in the microdialog.
Click Calculate to generate streamlines.
A new Surface Streamline entity is added to the Post Browser,
- Define the streamline display properties.
On the guide bar, click
to
confirm your selection and remain in the tool or click
to confirm your selection and exit the tool.
