Use the Boundary Groups tool to create a group of surfaces and define display properties. These surface groups can
be utilized to group boundaries as required and define specific display properties.
Use the Slice Planes tool to create derived geometry by slicing solids on a plane and defining display properties.
The result of slicing is a 2D planar face.
Use the Iso-Surfaces tool to a create a derived geometry surface with a specific constant scalar value and define
display properties. The shape of the iso-surface is dependent on domains and flow field.
Use the Streamlines tools to create derived geometry streamlines which represent particle paths in a flow field. You
have to define participating solids, seed points, and vectors from which streamlines are computed as well as the integration
direction. There are various methods to generate seed points.
Use the Probe Points tool to define a point or set of points at specific co-ordinates and probe/query results. This
is useful for verifying experimental results with simulation result.
Use the Calculate tool to create new field quantities using a python expression. The new fields can be derived from
existing fields or be completely independent of other results in the dataset.
and probe/query results. This is useful for verifying experimental results with simulation
result.
From the Post ribbon, click the Probe Points tool.
The Probe locations dialog opens.
Define probe points in the following ways:
Click directly in the modeling window to create
points and populate coordinates.
Click in the dialog to add a new probe point then
manually define the coordinates.
Click in the dialog, select a probe point, then use
the manipulators to adjust its position.
Tip: Click /
to import or export a probe point coordinates file.
Click Calculate on the guide bar
to extract values.
A new Point Probe entity is added to the Post Browser,
A table with extracted values for all variables is populated. This
data can be saved to a text file.
On the guide bar, click to
confirm your selection and remain in the tool or click
to confirm your selection and exit the tool.
