Create Streamlines
Use the Streamlines tools to create derived geometry streamlines which represent particle paths in a flow field. You have to define participating solids, seed points, and vectors from which streamlines are computed as well as the integration direction. There are various methods to generate seed points.
From the Post ribbon, click the Streamlines tool.
Figure 1. - Based on the requirement of the seed definition, select a tool on the secondary ribbon.
- Optional:
Select the solids on which to define streamlines.
Streamlines are restricted to participating solids. By default, all solids are selected.
Define seeds.
Tool Description Rectangle To generate random or uniform seeds on a rectangle object: - Click Plane on the guide bar.
- Select one of the three Cartesian planes in the modeling window.
- Use the microdialog options to align and resize the plane.
- Click Seeds on the guide bar.
- Choose a seed generation method and define the seeds.
- For the random and uniform methods, enter the number of seeds to insert.
- For the manual method, click on the plane to insert seed points.
- For any of the seed positioning methods, click on an individual seed point to edit its location.
Rake To generate seeds on a rake line: - Click Rake on the guide bar.
- Define a line by selecting two points.
Click on either end point or the entire line to reposition your selection.
- For the manual method, click on the rake line to insert seed points.
Circle To generate random or uniform seeds on a circle object: - Click Plane on the guide bar.
Points To generate user-defined seeds: - Click Seeds on the guide bar.
- Click on any visible surface or in empty space to generate
seeds.
- You can also click
in the dialog to create
seeds then define their coordinates manually. - Click on an individual seed point to edit its location.
Tip: Click
to import or export a
seed coordinates file. - You can also click
Surface To generate seeds on a surface: - Click Surface on the guide bar.
- Select surfaces on which to generate seeds.
- For the manual method, click on the surfaces to insert seed points.
Click
in the seeds microdialog to
select a vector variable and integration direction.
Note: For the Points tool, click
on the guide bar instead. -
Click Calculate to generate streamlines.
A new Streamline entity is added to the Post Browser,
- Define the streamline display properties.
On the guide bar, click
to
confirm your selection and remain in the tool or click
to confirm your selection and exit the tool.
Animate Streamlines
- Create streamline representation(s) using one of the approaches (rectangle, rake, and so on).
- Once a streamline representation is created, right-click on it in the Post Browser and select Animate.
Use the toolbar at the bottom of the modeling window to
control the animation.
The animation creates a proxy time to sweep through with the min and max automatically computed.
Click
to adjust the time steps.
