Tutorial
The process involved in SnRD workflows.
This tutorial document guides you through the process involved in SnRD Workflows, to setup an executable solver decks in order to capture and fix squeak and rattle problems in the components.
For purpose of illustration of SnRD tool capabilities, you shall make use of a car's Instrument Panel sub-assembly model .
Altair provides you with the files which are required for completing the following tutorial. The files required are listed in the Files Required topic.
