Import Models
Import external CAD line and surface data or finite element models. You can also import/merge HyperMesh model files (.hm) into the current model session.
Importing models allows you to import a single or multiple HyperMesh model files into the current HyperMesh session without deleting the current session.
  1. Import a model in the following ways:
    • From the menu bar, click File > Import > Model.
    • From the Standard toolbar, click (Import Model).
    The Import - Model tab opens.
  2. In the File Selection pane, click and select the file(s) to import.
    Remove files from the File Selection pane by clicking (Remove Selection) and (Remove All).
  3. Define Model Import Options by clicking to the left of Import Options.
  4. Click Import.
