Optimization Controls
Optimization control entities define and store controls for optimization problem run.
Optimization controls do not have a display state in the modeling window.
Nastran Cards
Card Description
DOPTPRM Overrides default values of parameters used in design optimization.
OptiStruct Cards
Card Description
DOPTPRM Defines design optimization parameters by overriding the defaults.
Note: Bulk Data Entry
If an unsupported argument is encountered on importing a DOPTPRM card, the data is stored as UNSUPPORTED_DOPTPRM on the DOPTPRM card.
It is also possible to create an unsupported DOPTPRM card using the UNSUPPORTED_DOPTPRM option on the opticontrol card image.
DOPTPRM, NESLEXPD Specifies the number of time steps retained for optimization from each EXPDYN subcase.
DOPTPRM, NESLIMPD Specifies the number of time steps retained for optimization from each IMPDYN subcase.
DOPTPRM, NESLNLGM Specifies the number of time steps retained for optimization from each NLGEOM subcase.
Radioss Cards
Card Description
BULK Used to insert bulk format data.
BULKFMT Used to define different OptiStruct formats (FREE, LARGEFREE, FIXED, or LARGEFIXED) during the Radioss-to-OptiStruct conversion.
BULKMAT Used to insert bulk format material card.
BULKPROP Used to insert bulk format property card.
ESLPART This keyword defines parts in the model, which will be included in ESLM optimization.
