HyperLaminate Toolbar
The HyperLaminate toolbar contains tools that allow you to generate new materials, laminates, HLS loadcases or design variables, and to cut, copy, paste, and delete entries in text boxes.
The HyperLaminate toolbar is located below the menu bar and its display is controlled by the Toolbar option under the View menu.
New
Generates a new entity, depending on the selected sub-topic in the Laminate Browser.
Cut
Removes the selected data from an entry field and places it on the clipboard for pasting.
Can also remove rows from a ply lay-up order table and place these on the clipboard for pasting.
Copy
Places selected data from an entry field on the clipboard for pasting.
Can also place rows from a ply lay-up order table on the clipboard for pasting.
Paste
Pastes data from the clipboard in selected entry fields.
Can also paste rows from the clipboard above selected rows on a ply lay-up order table.
Delete
When the cursor is active in the Laminate Browser, this deletes the selected entity from the Laminate Browser. A dialog is displayed to confirm the deletion.
When the cursor is active in the Define/Edit pane, this deletes the selected text from a text box or the selected rows from a ply lay-up order table.
