Set Up an Auto Contact Run
  1. Load the ANSYS user profile.
  2. From the Tools menu, select Ansys Surface Manager.
  3. Click Auto.
    The Auto Contact dialog opens.
  4. In the Contact Type: field, select the type of contact pair to create.
  5. Click the yellow components button to select your components.
    The components are automatically placed in the Component table in the Auto Contact dialog. The proximity distance is the maximum distance between two selected components. When you create the pair, any surfaces that are farther away than the value entered here will not be created as a contact pair. The default value is zero.
  6. In the Maximum reverse angle field, enter a value.
    If the angle between two normals of elements or element faces exceeds this value, the element will not be added to the main or secondary surface.
  7. Click Find.
    The status bar activates and the Auto Contact browser opens.
  8. Use the Auto Contact browser to make any necessary adjustments to the interface and surfaces. When finished modifying, click Create.
    The interfaces and surfaces marked as accepted are created. The Contact Manager window reopens with the new information listed.
