Plot an Order in an XY Plot Window
  1. From the HyperGraph 3D Data Query panel, select one or more cut surfaces from the Cut list.
  2. Under Create curve:, from the first drop-down menu, select the X, Y, or Z axis of the 3D plot as the independent axis for the created curve.
  3. Under Create curve:, from the second drop-down menu, select the X, Y, or Z axis of the 3D plot as the dependent axis for the created curve.
  4. Set the Layout to One plot or One plot per cut to place all created curves in one plot window or each curve in its own plot window, respectively.
