Define a Datum Plane's Location and Orientation Based on a Math Expression and Curve Data
  1. From the HyperGraph 3D toolbar, click the Datum Planes icon, .
  2. Select a datum plane from the Datum list.
  3. Select the Position tab.
  4. Under Location:, enter a math expression in the X=, Y=, and/or Z= fields to define the plane’s location along its normal.
    Curve data can be referenced by using p#w#c#.vector. For example, mean(p1w1c1.z) indicates the z vector of page 1, window 1, curve 1.
