Curves View
The Curves view, , displays the session's curves in the Plot Browser's tree structure, grouped within their respective page and plot folders.
To apply a filter on a curve or on an x or y vector property, right-click on the curve or x/y vector’s property in the Entity Editor and select Add as filter.
All text fields which support Templex have now two add filter options, Add as Filter and Add as unevaluated Filter. This allows you to add the unevaluated Templex code as a filter.
Figure 3.
After a value is given to that filter, all curves or vectors with that value for that property are shown in the browser. Vectors are displayed with their corresponding curves. See Plot Browser Filter for more information.
Vectors are shown in the Plot Browser tree as items under their corresponding curves. Clicking on a curve displays the curve's properties in the Entity Editor; clicking on a vector displays the vector's properties in the Entity Editor.
Figure 4. Entity Editor when File is selected as the data source
Figure 5. The Entity Editor options change when the Math or Values options are selected as the data source
Figure 6.
The following curve and vector (entity type) properties are visible and editable through the Entity Editor.
Curve Properties
Standard
Visibility
Turns on/off the curve display in the modeling window.
Layer
Bar View Style
For bar plots, select Bar or Line to define how the bar plot is displayed.
Reference
Makes the selected curve(s) a reference curve(s). See Reference Curve for more information.
Curve Label
Show Label
Displays the curve's label in the modeling window legend.
Label
When selected, the values are displayed in the legend as a label. Label prefix and Label suffix are updated with new options, and .
MaxY/At X
Display the maximum Y value of the curve with the X coordinate in the legend as a label.
Show Label Prefix/Show Label Suffix
Curve prefix and suffix shortcuts in a Templex expression are supported from the entity editor. For example, if a note is attached to a curve, it can access suffix and prefix information using a Templex expression like {p1w1c1.suffix} and {p1w1c1.prefix}.
Line Attributes
Line Style
Select a line style from the menu to apply to the selected curve.
Line Color
Select a curve color from the color palette.
Line Thickness
Select a line thickness for the curve from the menu.
Shade Area
Fills the area under the curve with a solid color.
Shade Style
If Shade Area is selected, Shade Style is displayed. Select from the following options:
  • Zero X
  • Zero Y
  • Left
  • Right
  • Top
  • Bottom
  • Inside
Bar Attributes
Bar Color
Select a bar color from the color palette.
Bar Fill Style
Fill the bar with the selected pattern.
Symbol Attributes
Symbol Style
Symbols can be placed on a curve to indicate data points. Select a symbol type from the list.
Symbol Color
Select a symbol color from the color palette.
Symbol Frequency
Set the frequency of the symbol placement. Default is 1, where a symbol is placed at every data point. If you enter 5, a symbol is placed at every fifth data point, for example.
Symbol Scale Size
The symbol size.
Axis Attributes
Value Axis
For bar plots only. Select the value axis from the drop-down menu.
Vector (Entity Type) Properties
Data
Source
The source type: File, Math, or Values.
File
If Source is File, the file path is displayed.
Expression
If Source is Math, the math expression is displayed.
Values
If Source is Values, the vector data values are displayed.
Subcase
Displays the subcase.
Type/Request/Component
Displays the type, request, and component data for the vector.
For Request, double-click on the currently selected request to display the Define Vector dialog. Enter a string to filter the request list. The matching requests are displayed at the top of the list.
Figure 7.
Standard
Scale
Select 1 or -1 as the scale value for the curve.
Offset
Enter an offset value.
First Value
The first data point of the vector.
Max Value
Maximum vector value.
Min Value
Minimum vector value.
User Expression
Axis Assignment
The curve the axis is associated with.
Units
The unit type.
Measurement
Change curve vector units from the Measurement menu.
You can also select a curve from the Plot Browser and delete it by pressing the Delete keyboard key.
From the Scale drop-down menu in the entity editor, the values 1 and -1 are the only options allowed for vector scaling if units are enabled.
Figure 8.
