2022
Annotate model results using the Measures, Notes, Tracing, Image Planes, and Build Plots tools.
Use the Tracing tool to trace system, component, and node entities during animation.
View new features for HyperView 2022.
Discover HyperView functionality with interactive tutorials.
Create and import/export sets, create user defined coordinate systems, or use the symmetry visualization tool.
Explore the various result plotting tools.
Use the Measure tool to measure various distances and angles between entities.
Use the Notes tool to label items, describe trends, and relate additional information.
The Image Plane tool allows you to select and overlay images (such as company logos, watermarks, etc.) or videos in the graphics area for correlation and presentation purposes.
Use the Plots tool to construct multiple curves and plots from a single result file.
From the Tools menu, you can access various panels and dialogs.
From the Preferences menu, you can define file export settings and access the Options dialog.
The Aerospace menu provides you with access to various aerospace tools.
The NVH menu provides you with access to various NVH utilities.
The Vehicle Safety Tools (VST) is a collection of over 200 macros, Templex functions, and external functions for use by a vehicle safety engineer.
A new workflow emphasizing upfront data loading for standard crash post processing use cases.
Supported solvers in HyperView.
HyperView help for HyperWorks.
View All Altair Simulation Help
To delete the current reference line.
