Notes
Use the Notes tool to label items, describe trends, and relate additional information.
Notes are text boxes that can be used to annotate Animation files. The Notes tool supports Templex functions, allowing you to perform calculations and other data analysis within a note. The information in a note changes as a model animates.
The names of all the notes in the active window are displayed in the Notes list. You can add and delete notes from the list. Check boxes allow you to display one or more notes. You can also sort the items in the Notes list by clicking on the list heading. In addition, keyboard shortcuts and a context menu are available for items within the list.
From the Annotations toolbar, click Notes .
Note: You can also select Notes from the Annotations menu.
Figure 1. Notes Panel
Attention: Notes cannot be created in an empty window, therefore a model must be loaded prior to using this tool.
