Change Note Attributes
Note: Each attribute setting is applied immediately upon
            selection.
                From the Annotations toolbar, click Notes
- From the Notes panel, select a note in the Notes list.
- Under Display options, activate the Transparency check box to remove the color from within the note box and make it transparent against the window.
                Activate the Auto-hide check box to hide the note box
                    when the entity that the note is attached to is not visible on the screen.
                Note: This applies to all entities (except systems) that are hidden by section cuts.
                Activate the Move to entity check box to position the
                    note at the attachment location.
                Note: This option is disabled if Window has been selected from the Attach To drop-down menu.
                Select Anchor to Screen to have the note remain
                    stationary during animation or when manipulating the model view (rotating,
                    zooming, etc.).
                Note: This option is disabled if Window has been selected from the Attach To drop-down menu.Tip: Activating the Move to entity check box will automatically override the Anchor to Screen option (if activated).
- Click the Color box and select a new color for the note.
                Click the Fill Color box and select a new fill color for
                    the note.
                Note: This option is disabled if the Transparency option is activated. You must remove the check mark from the Transparency option in order to select a fill color.
- From the Align text drop-down menu, select the Left, Center, or Right alignment.
                From the Border drop-down menu, select No Border, or a
                    border thickness to apply to the note box.  . .
