Assembly Output Example
This example demonstrates how to use template files to generate output files for assemblies.
*assemblies()
  *format()
    *string("ASSEMBLY: ")
    *field(integer,id,0)
    *string(" ")
    *field(quotedstring,name,0)
    *end()
    *counterset(counter1,0)
    *loopif([counter1 != numberofcomponents])
      *pointerset(pointer1,components,counter1)
      *string("   COMPONENT: ")
      *field(integer,pointer1.pointervalue,0)
      *string(" ")
      *field(quotedstring,pointer1.component.name,0)
      *end()
      *counterinc(counter1)
    *endloop()
    *loopif([counter1 != numberofassemblies])
      *pointerset(pointer1,assemblies,counter1)
      *string("   SUBASSEMBLY: ")
      *string(" ")
      *field(quotedstring,pointer1.assembly.name,0)
      *end()
    *endloop()
    *loopif([counter1 != numberofmultibodies])
      *pointerset(pointer1,multibodies,counter1)
      *string("   MULTIBODY: ")
      *string(" ")
      *field(quotedstring,pointer1.multibody.name,0)
      *end()
    *endloop()
*output()
