Input Format
- Each entity description command begins with an asterisk, *
 - Each entity description command ends with a pair of parentheses, ()
 - The entity description command parameters are separated by commas and contained in parentheses.
HyperMesh restricts the placement of certain entity descriptions in an ASCII input file. For example, in the HyperMesh database, elements must exists within a component. Element descriptions must follow component descriptions so that elements are loaded into the correct component during input.
You can place any number of each entity description command in the input file.
- Command description
 - Required arguments
 - Argument data type
 - Argument description
 - Example
 - Comments
The string data type is a list of up to 32 characters enclosed in double quotes. The string data type can include spaces.
