Examples
There are several example custom readers available in <altair_home>/hm/examples. Each example includes the code, Visual Studio project files for building on Win32/Win64, and Unix/Linux makefiles.
hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
ON THIS PAGE
ON THIS PAGE
