Solver Attributes and Data Names
Solver specific data created from the HyperWorks Desktop template system is stored in card images. Each piece of data that defines a card image has a text string (data name) and a numeric attribute ID.
An example is the Young’s Modulus for a material. Each solver, and even each different material type for a particular solver, can have a Young’s Modulus attribute and a corresponding data name. These data names and attributes are defined in each solver’s feoutput template. They are unique and are not necessarily consistent between solvers or even between each material within a solver.
Templates exist for each solver supported by HyperWorks Desktop and are located in subfolders under the <altair_home>/templates/feoutput directory. These templates define every solver specific attribute including data names, attribute IDs, card image formats, and the format of the data upon export. The *defineattribute command is used to define attribute data names and IDs in a template file.
Solver data names are not documented, as they may change often as the templates that define them are updated or new solver card support is added.
There are several different types of attributes including array, double, entity, integer and string. Each of these types is handled in a similar fashion to the examples below. The *setvalue command may be used to update them, and hm_getvalue to query them. There are also a number of hm_attribute commands to query entity attributes in specific ways.
Solver Attributes and Card Images
A sample card image for an OptiStruct MAT1 material collector in the is shown below.
For each field in the above dialog there is a corresponding attribute and data name in the OptiStruct template. An excerpt is shown below for several of the card image fields:
*defineattribute(E,1,real,none)
*defineattribute(G,2,real,none)
*defineattribute(Nu,3,real,none)
*defineattribute(Rho,4,real,none)
The first argument in the *defineattribute command is the solver data name. The second is the attribute ID and the third is the attribute type. There are 11 different attribute types. Attributes of different types are created and updated with different commands, but the overall concept is the same.
Each attribute in the template has a definition similar to these. Additionally, there are card image definitions that define how the card editor is generated inside of HyperWorks Desktop for each attribute. An excerpt of the OptiStruct MAT1 card image is shown below:
*menustring("MAT1    ")
*menufield(ID,integer,id,8)
    *menufield(E,real,$E,8)
    *menudefaultvalue("        ")
    *menuinitialvalue(210000.0)
    *menurestrictedvalue(>,0.0)
*menufield(G,real,$G,8)
    *menuinitialvalue(80769.2)
*menufield(NU,real,$Nu,8)
    *menurestrictedvalue(>,-1.0)
    *menurestrictedvalue(<,0.5)
    *menuinitialvalue(0.3)
*menufield(RHO,real,$Rho,8)
    *menuinitialvalue(7.85e-09)
Notice the *menufield command used above. This command determines how a field is created in the Card Editor for a particular attribute. The first argument is the text string to show above the data field and the third argument is the particular data name that is associated with that field. For example, the attribute and card image definitions for the Young’s Modulus for the MAT1 material are:
Knowing all of this information allows you to assign, update and query the data.
Assigning Data to Solver Attributes
It is easiest to understand how to assign data to solver attributes with a specific example. When the MAT1 material collector shown above is initially created, the relevant commands to assign values to its attributes are written to the command file. Note that the values correspond to those shown in Figure 1:
*createentity materials name=steel color=11 cardimage=MAT1
*setvalue materials id=1 STATUS=1 1=210000;
*setvalue materials id=1 STATUS=1 2=0;
*setvalue materials id=1 STATUS=1 3=0.3;
*setvalue materials id=1 STATUS=1 4=7.85e-009;
*setvalue materials id=1 STATUS=1 5=0;
*setvalue materials id=1 STATUS=1 6=0;
*setvalue materials id=1 STATUS=1 7=0;
*setvalue materials id=1 STATUS=1 8=0;
*setvalue materials id=1 STATUS=1 343=0;
*setvalue materials id=1 STATUS=1 345=0;
*setvalue materials id=1 STATUS=2 5237=0;
Each of these commands sets one of the MAT1 attributes either to its default value or to the user defined value.
Looking at the OptiStruct template, attribute 1 corresponds to the data name E, or Young’s Modulus.
Simply running these commands as-is is not very flexible. The material ID, name and values are all hard coded. Finally, there are a lot of extra commands that set attributes that are not necessary.
Creating a Reusable and Modular Procedure
In order to make this more flexible, you can create a Tcl procedure that allows you to substitute variables for the name, color and data values. You can also make the template file path modular across different platforms and make the material ID a variable that references the newly created material name so the *setvalue commands works properly.
proc mat_create { name color E Nu Rho } {
    if {[hm_entityinfo exist mats $name -byname] == 1} {
        hm_errormessage "Material $name already exists"
        return;
    } else {
        *createentity materials name=$name color=$color cardimage=MAT1;
        *setvalue materials name=$name 1=$E;
        *setvalue materials name=$name 3=$Nu;
        *setvalue materials name=$name 4=$Rho;
        return;
The advantage of doing this is that mat_create is now modular. The developer need only pass the material name, color and the values for the material properties and the procedure will create the material accordingly.
Updating Solver Attributes
In addition to creating a card image from scratch, it is also possible to update an existing card image. A procedure to do this is almost identical to the procedure to create a new image, with the exception that the material is not created and thus the procedure requires a material ID to be passed instead of a material name.
proc mat_update { mat_id E Nu Rho } {
    if {[hm_entityinfo exist mats $mat_id -byid] == 0} {
        hm_errormessage "Material $mat_id does not exist"
        return;
    } else {
        *setvalue materials id=$mat_id cardimage=MAT1;
        *setvalue materials id=$mat_id 1=$E;
        *setvalue materials id=$mat_id 3=$Nu;
        *setvalue materials id=$mat_id 4=$Rho;
        return;
Make sure to pay close attention to the information you wish to update, and update only those fields.
Querying Solver Attributes
In addition to the standard HyperWorks Desktop data names, data names also refer to solver specific attributes as described above. Solver data names are accessed similarly to HyperWorks Desktop data names, using the hm_getvalue command.
These commands use a data_name_string to access a particular piece of data. As noted above, each attribute has both an ID and a data name. For example, from the MAT1 material card there are several attributes of interest:
Again, the first argument is the solver data name and the second is the attribute ID. So in order to extract the value of E from a material with ID 11:
hm_getvalue mats id=11 dataname=E
Below is a procedure to extract the data from a MAT1 card image and show the values in the HyperWorks Desktop status bar:
proc mat_query { mat_id } {
        return;
    } else {
        set E [hm_getvalue materials id=$mat_id dataname=E];
        set Nu [hm_getvalue materials id=$mat_id dataname=Nu];
        set Rho [hm_getvalue materials id=$mat_id dataname=Rho];
        hm_usermessage "E=$E Nu=$Nu Rho=$Rho"
