ardi.item
Report Item: access/modify Report Items.
ardi.item.chapter
Interact with items of type chapter. This item type is valid only for document reports.
Supported property names are:-name-value-parent-type (read only).
All properties available can be passed via the "create" API or modified on an existing item via the "set" API.
ardi.item.chapter.create
Creates an item of type "chapter".
For
Value: A full list of property names see "Supported property names" above.
Returns
The ID of the item or Python-error in case an error occurred during creation.
ardi.item.chapter.create -name "My Chapter Item"
ardi.item.chapter.delete
Deletes the item with the specified ID.
-id
Mandatory value: Item ID. The item ID which is returned by the corresponding "create" API.
Returns
1 for OK, Python-error in case of error.
ardi.item.chapter.delete -id $id
ardi.item.chapter.get
Queries the value of one property.
-id
For
Returns
The value of the specified property or Python-error in case of error.
ardi.item.chapter.get -id $id -property parent
ardi.item.chapter.set
Sets one or multiple parameters to specified values. The type of the item is assigned upon creation and cannot be changed after.
-id
Mandatory Value: Item ID. The item ID which is returned by the corresponding "create" API.
For
Returns
ardi.item.chapter.set -id $id -name "My Chapter Item" -value "Good monring, how are you today?"
ardi.item.chapter.hasproperty
Check if the item has property with specified key.
-id
Value: Item ID.
-key
Value: Property key.
Returns
1 if valid, 0 if invalid.
ardi.item.exceldocument
Interact with items of type exceldocument.
Supported property names are:-name-value-parent-type (read only)-file-sheet-caption-capitalisation.
ardi.item.exceldocument.create
Creates an item of type "exceldocument".
For
Returns
ardi.item.exceldocument.create -name "My External Excel Document Item"
ardi.item.exceldocument.delete
-id
Returns
ardi.item.exceldocument.delete -id $id
ardi.item.exceldocument.get
-id
For
Returns
ardi.item.exceldocument.get -id $id -property parent
ardi.item.exceldocument.getcell
Queries the value of one property from table cell.
-id
-row
Mandatory value: Row ID. Row ID is an integer starting from 0.
-column
Mandatory value: Column ID. Column ID is an integer starting from 0.
-property
Mandatory value: Property name. 'value' or 'href'
Returns
ardi.item.exceldocument.getcell -id $id -row 0 -column 0 -property values
ardi.item.exceldocument.getpropertyid
Queries id of property.
-id
Value: Item ID.
-key
ardi.item.exceldocument.getpropertykeylist
Queries list of properties.
-id
-row
Value: Item ID.
Returns
List of property keys for a particular item ID.
ardi.item.exceldocument.set
-id
For
Returns
ardi.item.exceldocument.set -id $id -name "My External Excel Document" -file "c:/temp/mydoc.xlsx"
ardi.item.exceldocument.setcell
Sets one or multiple parameters to table cell.
-id
-row
-column
-value
Value: The value you want to set on the cell.
-href
Value: Object ID to hyperlink.
Returns
ardi.item.exceldocument.setcell -id $id -row 0 -column 0 -value "Hello" -href $refobjid
ardi.item.image
Interact with items of type image.
Supported property names are:-name-value-parent-type (read only)-config-hwpage-hwwindow.
ardi.item.image.create
Creates an item of type "image".
For
Returns
ardi.item.image.create -name "My Image Item"
ardi.item.image.delete
-id
Returns
ardi.item.image.delete -id $id
ardi.item.image.get
ardi.item.image.get
-id
For
Returns
ardi.item.image.get -id $id -property parent
ardi.item.image.set
ardi.item.image.set
-id
For
Returns
ardi.item.image.set -id $id -name "My Image Item" -value "Good monring, how are you today?"
ardi.item.module
ardi.item.module.create
Creates an item of type "module".
ardi.item.module.delete
-id
Returns
ardi.item.module.get
Gets property value of an Item.
ardi.item.module.set
Sets property value of an Item.
ardi.item.pagebreak
ardi.item.pagebreak.create
Creates an item of type "break".
For
Returns
ardi.item.pagebreak.create -name "My Image Item"
ardi.item.pagebreak.delete
-id
Returns
ardi.item.pagebreak.delete -id $id
ardi.item.pagebreak.get
-id
For
Returns
ardi.item.pagebreak.get -id $id -property parent
ardi.item.pagebreak.set
-id
For
Returns
ardi.item.pagebreak.set -id $id -name "My Image Item" -value "Good monring, how are you today?"
ardi.item.property
ardi.item.property.create
Creates an item of type "property".
-id
Mandatory value: Parent item ID of type text, image, table, module\parent.
-key
Mandatory value: Unique key/name for the property.
-name
Value: "Display name of the property, if not specified key is used as display name".
-type
(defaults to str): Type of property.
For
Returns
ardi.item.property.create -id $parentid -key "MyKey" -name "My Property" -value "My Value" -type "str"
ardi.item.property.delete
-id
Mandatory value: Parent item ID of type text,image,table,module etc, \parem
-name
Mandatory value: Name of the property.
Returns
ardi.item.property.delete -id $id
ardi.item.property.get
-id
For
-column
-property
Returns
ardi.item.property.get -id $id -property parent
ardi.item.property.set
Sets name and value of specific property.
-id
For
Returns
ardi.item.property.set(id=itemid,value="Test")
ardi.item.slide
ardi.item.slide.create
Creates an item of type "slide".
For
Returns
ardi.item.slide.create -name "My Slide Item"
ardi.item.slide.delete
-id
Returns
ardi.item.slide.delete(id=itemid)
ardi.item.slide.get
ardi.item.slide.get
-id
For
Returns
ardi.item.slide.get -id $id -property parent
ardi::item::slide set
-id
For
Returns
ardi.item.slide.set(id=itemid,name="My Slide Item",value="Good monring, how are you today?")
ardi.item.table.
Interact with items of type table.
Supported property names are:-name-value-parent-type (read only)-numberless-numberofcolumns -showcolumnheader-showrowheader.
ardi.item.table.create
Creates an item of type "table".
For
Returns
ardi.item.table.create -name "My Table Item"
ardi.item.table.delete
-id
Returns
ardi.item.table.delete -id $id
ardi.item.table.get
ardi.item.table.get
-id
For
Returns
ardi.item.table.get -id $id -property parent
ardi.item.table.getcell
Queries the value on a cell identified by row and column ID. Row and column IDs start with 0.
-id
-row
Mandatory value: Row ID. The ID of the row.
-column
Mandatory value: Column ID. The ID of the column.
-property
Mandatory value: 'value', 'href', 'color', 'textcolor', 'fontname', 'fontstyle', 'horizontal_alignment' and 'vertical_alignment'.
Returns
The value of the cell, Python-error in case of error.
ardi.item.table.getcell(id=itemid,row=0,column=0)
ardi.item.table.getheader
Queries the header text on a row or on a column. Row and column IDs start with 1. Specify either row or column ID to query the current value.
-id
-row
Value: Row ID. The ID of the row you want to query the header text.
-column
Value: Column ID. The ID of the column you want to query the header text.
Returns
The header text, Python-error in case of error.
ardi.item.table.getheader -id $id -column 1
ardi.item.table.set
ardi.item.table.set
-id
For
-column
Returns
ardi.item.table.set -id $id -name "My Table Item" -value "Good monring, how are you today?"
ardi.item.table.setcell
Sets the value on a cell identified by row and column ID. Row and column IDs start with 0.
-id
-row
-column
-value
-href
Value: Object ID to set cross-reference to.
Returns
ardi.item.table.setcell -id $id -column 1 -value "My Header Text on column 1"
ardi.item.table.setheader
Sets the header text on a row or on a column. Row and column IDs start with 0. Specify either row or column ID to set the header text to desired value.
-id
-row
Value: Row ID. The ID of the row you want to set a particular header text.
-column
Value: Column ID. The ID of the column you want to set a particular header text.
-value
Value: The text you want to set as header of the specified row or column ID.
Returns
ardi.item.table.setheader(id=itemid,column=1,value="My Header Text on column 1") i.e ardi.item.table.setheader(id=itemid,row=2,value="My Row Header")
ardi.item.tableofreference
Interact with items of type tableofreference.
Supported property names are: -name-value-parent.
All properties available can be passed via the "create" API or modified on an existing item via the "set" API. After creation all the properties that applies for table type can be used.
ardi.item.tableofreference.create
Creates an item of type "tableofreference".
For
Returns
The ID of the item type table or Python-error in case an error occurred during creation.
ardi.item.tableofreference.delete
-id
Returns
ardi.item.tableofreference.delete(id=itemid)
ardi.item.tableofreference.get
-id
For
Returns
ardi.item.tableofreference.get(id=itemid,property='parent')
ardi.item.tableofreference.set
-id
For
Returns
1 for OK, python-error in case of error.
ardi.item.tableofreference.set(id=itemid,name="My Table of References" -parent $parentid"
ardi.item.text
Interact with items of type text.
ardi.item.text.create
Creates an item of type "text".
For
Returns
ardi.item.text.create(name="Text1",value="My Text Content")
ardi.item.text.delete
-id
Returns
ardi.item.text delete(id=itemid)
ardi.item.text.get
ardi.item.text.get
-id
For
Returns
ardi.item.text.get(id=itemid,property='parent')
ardi.item.text.getcrossref
Queries the cross reference within text item.
-id
ardi.item.text.set
ardi.item.text.set
-id
For
Returns
1 for OK, -Python-error in case of error.
ardi.item.text.set(id=itemid,name="My Text Item",value="Good monring, how are you today?")
ardi.item.text.setcrossref
Sets the cross reference within text item.
ardi.item.textdocument
Interact with items of type textdocument.
Supported property names are:-name-file-parent.
ardi.item.textdocument.create
Creates an item of type "textdocument".
For
Returns
ardi.item.textdocument.create(name="My Text File",file="example.txt")
ardi.item.textdocument.delete
-id
Returns
ardi.item.textdocument.delete(id=itemid)
ardi.item.textdocument.get
-id
For
Returns
ardi.item.textdocument.get(id=itemid,property='parent')
ardi::item::textdocument.set
-id
For
Returns
ardi.item.textdocument.set(id=itemid,name="My External Excel Document",file= "c:/temp/textdocument.txt")
ardi.item.worddocument
Interact with items of type worddocument.
ardi.item.worddocument.create
Creates an item of type "worddocument".
For
Returns
The ID of the item or python-error in case an error occurred during creation.
ardi.item.worddocument.create(name="My Word Document",file="example.docx")
ardi.item.worddocument.delete
-id
Returns
ardi.item.worddocument.delete(id=itemid)
ardi.item.worddocument.get
-id
For
Returns
ardi.item.worddocument.get(id=itemid,property='parent')
ardi.item.worddocument.set
-id
For
Returns
ardi.item.worddocument.set(id=itemid,name="My External Word Document",file ="c:/temp/example.docx"
ardi.item.apply
For better performance data created, manipulated or deleted go into a cache.
ardi.item.apply
-name
Value: Layout name to use in case of presentation.
-itemlist
Value: List of item ids to apply.
-parent
Value: parent of the cached items. If not specified root item will act as a parent. This API processes the cached data, clears the cache and redraws the GUI if needed.
-property
Mandatory value: Property name. 'value' or 'href'.
Returns
ardi.item.delete
ardi.item.delete
-id
Value: Item ID.
Returns
ardi.item.get
Queries the value of one property or role or attribute.
ardi.item.get
-id
For
Returns
The value of the specified property/role/attribute or python-error in case of error.
ardi.item.get -id $id -property parent
ardi.item.get -id $id -role rolename
ardi.item.get-id $id -attribute attributename
ardi.item.getpropertyid
Queries ID of property.
-id
Value: Item ID.
-key
ardi.item.getpropertykeylist
-id
Value: Item ID.
Returns
ardi.item.getslidelayouts
Queries slide based layouts.
Returns
The list of slide layout IDs.
ardi.item.getmasterlayouts
Queries master layouts.
Returns
The list of master layout ID's.
ardi.item.gettype
Queries the type of the item with the specified ID.
ardi.item.gettype
-id
Value: Item ID.
Returns
The type of the item.
ardi.item.gettypelist
Queries available types of items.
Returns
A list of item types.
ardi.item.hasproperty
-id
Value: Item ID.
-key
Returns
ardi.item.isvalid
Check if the item with the specified ID is valid.
ardi.item.isvalid
-id
Value: Item ID.
Returns
ardi.item.set
ardi.item.set
-id
For
Value: A full list of standard property names see "Supported property names" above. Use rpti::item getpropertykeylist for list of dynamic properties.
Returns
ardi.item.set -id $id -name "My Text Item" -value "Good monring, how are you today?"
